hi all,well my lumps finaly out off my gtr32.just drained the oil(god thas was well black to say the least,and only done 2k miles with it!!)anyways going to get the crank out and get it ground down so the crank collar will fit.then after that it will be balanced as ive just got a triple plate clutch and flywheel(so proberly best i get it balanced again.whats another £150:chuckle
.so finaly my question is why do they supply 2no little grub screws with the crank collar? surely with the collar being heat shrunk on they wouldnt need 2xgrub screws to be fitted?there isnt any pre-drilled holes either in the crank collar for the screws?? im sure theres a very simply answer?? and im also going to be after some torque setting to if anybodies got them to hand
thanks guys.. :thumbsup:
