Please anyone can help me with the question about rb26 crankshaft.
Is there any difference between crankshafts from different GTRs (32-33-34)??
I have two opinions: first is that all is the same.
And some strange but very hard opinion that in some very early engines the cranks necks is narrow, and after they become wider.
So on this crank the oil pump is not fixed across all its width, but only in a half. It is bad because when the power is higher then stock, the probability that crank will break the pump (internal gear) exists. On such a crank is not advisable to start with a cut-off (it can break the oil pump) and turn the above 8000 rev (can break the oil pump).
So please can you kindly share your knowledge?
