Nope, it's a b*stard, just done mine. Went through 5 seals before getting it right. I bought some aluminium tubing the same diameter as the seal edge where it fits over the crank. Used the crank bolt and a piece of wood with a hole in the middle and turning the bolt to fit the seal. If, the lip doesn't fit over properly I used a blunt screwdriver to carefully push it in, but takes practice and that's why it took me 6 times.
