Hi guys I recently had the 36 month service which includes four wheel alignment and I've noticed that when I move off very slowly forward or in reverse I get a creaking sound coming from the rear end, it sound like dry coil springs, I've sprayed clear grease in all the joints and links and joints and made no difference. Any ideas has anyone else had this problem. Cheers
Hi I had the drop links checked and it's not them causing the problem, the confusing thing is that it only makes the noise once the rear wheels rotate about three quarters then it creaks and then disappears until they reach the same position again, checked it underneath and nothing is touching at that point and it seems to do it more when the car is first started and moved off slowly
