Pre-owned Cusco Adjustable Upper Arms Set (Front and Rear) for the R33 and R34 Nissan Skyline.
Via fitment of the 4-stage adjustable front upper arms, cornering performance will be increased as tires contact patch increases. These are crucial if you want to adjust the camber of your R33 / R34 Nissan Skyline. They offer adjustment values as per below:-
+5 mm
± 0 mm
-5 mm
-10 mm
The adjustable rear upper arms are adjustable via the turn buckle. This will enable adjustments on the camber from +10mm to -6mm.
Vehicle compatibility for the set as below:-
Skyline - R33 GTS-t S1 - ECR33
Skyline - R33 GTS-t S2 - ECR33
Skyline - R33 GTR - BCNR33
Skyline - R34 GTR - BNR34
Skyline - R34 GTT - ER34
GBP255
+5 mm
± 0 mm
-5 mm
-10 mm
GBP255
