1 - 11 of 11 Posts
If anyone is after some Cusco / BRIDE parts, please shout. The container just arrived.
Check out our warehouse currently!
And still the container is half empty!
R35 and R32 GTR rollcages in stock
Get in touch if you're after BRIDE or Cusco parts
Graham, we have multiple cages in stock for R35 at the moment.
1x Cusco Cr/Mo material (light weight) 4 point cage + X bar + harness bar in the colour black
And 1x the same, but in Steel (which is a bit heavier and a bit cheaper).
You can leave the full interior in, incl. subwoofer.
@ Tim, as you know, that's just the only way to make it properly work. We did order a lot of suspension kits for stock aswell. You know how to find us if you need anything.
Is the harness bar the one that goes through the subwoofer plastic piece? I have dont have the standard sub, so not sure if that bar will fit. The rest looks quite good. Price?
Discussion Starter · #8 ·
Yes, that's the harness bar. It's probably the only way it would work. If you would move the bar to the main hoop, you wouldn't be able to slide the seat back.
1 - 11 of 11 Posts
