This was used on my Time Attack car. It was fabricated for us specially and sits where the washer bottle does on a standard R33. It comes with proper ID hose to run from the rocker covers and is the correct length.
It also has an outlet to return the oil back to the sump. I had it set up to drain back to the sump via the front turbo drain, this hose can be included with this or you can simply block the hole up and just use it as a catch tank.
It is filtered on the top.
I am looking for offers int he region of £170 as that is what it owes me.
