• 1995 Series 1. V Spec Car - BN6 Blue - 92,000 Km's on the clock (clocks up in kms)
• Standard Block rebored to 2.8L with HKS Step 2 Kit
• Crackle finish Cam Covers
• Abbey Motorsport 2.8l coil cover dressing plate
• Greddy Radiator diverter plate Cooling panel
• HKS Spec S FMIC (Front Mount intercooler kit)
• HKS Step 2 Crank
• HKS Step 2 Pistons
• HKS Step 2 Rods
• HKS Oil Pump
• Abbey Motorsport modified head with oil gallery modified
• HKS steel head gasket
• HKS fuel pump (single)
• HKS Hi Power Exhaust (not Stainless)
• HKS power flow bit filter
• AEM trigger crank sensor
• Nismo N1 Water pump
• ATI Crank damper
• Garrett GT4088r turbo
• Link G4+ with 2 level boost (1.2 bar and 1.5 bar) control knob in coin tray
• Link Knock link to ECU
• Tial Wastegate
• Splitfire Coils
• Injectior dynamics 720cc injectors
• 6 Boost Manifold
• Abbey motorsport custom made downpipe
• Cat replacement pipe
• Mishimoto Readiator (Less than 12 months old)
• SFS Silicon pipework
• BC Coilover Suspension
• Flocked Dash
• N1 Bumper Vent
• ALCON 6 Pot 356mm Front Brake kit
• Master Cylinder Brake Stooper
• OMP Leather steering wheel
• Nismo White Side Indicators
• Nismo White Front Indicators
• Nismo Wing End Plate Garnish Trims
• Nismo B post Garnish Trims
• Nismo Gear knob
• Nismo Short throw gear lever kit
• Torque Split controller with control knob in coin tray
• Flocked dash with Boost gauge at eye level - modified air vent to do this
• Toad Immobiliser
• Relocated power steering reservoir
• Power Steering cooler
• 19 Row Oil Cooler Kit
• Nismo white faced 320kph speedo (speedo converter removed reads in KPH - should see a jump in MOT readings)
• GPS head up speedo for MPH reading
• Nismo white faced centre gauges
• Oil temp , Water temp . EGT temp gauges in stereo position
• Driver seat - lowered subframe and Cobra Imola Xl seat
• Head lining recovered in Black fabric
• Sun visors removed
• Rear wash wipe removed
• Aerial removed
• Headlight converted to HID
• Rear seat belts removed
• AC system removed
• Abbey Motorsport ancillary belt tensor fitted
• Rota 18 x 10J Alloys with Michelin Pilot Cup 2 tyres 265/40/18
• Abbey Motorsport replaced strut tops (2017 - Will H)
• Abbey Motorsport Combined catch can and wash wipe water reservoir
• Aerocatch fitted to bonnet
• Mapped at 569HP at 1.5bar at hubs by Mark at Abbey Motorsport
https://youtu.be/8TgQwn9KNo8
25995 gpb
Do you know exactly what rods were used? I-beam or H-beam? Would PM about the car but new to forums. Do you have a mobile number I could call? Thanks.
