I have an 96' R33 GTR.
Does anyone know what speed pulse to set the Concept to in order to correctly get a speed reading?
The set up parameters can be either 2-4-8-16 or free.
Also, if the incorrect pulse was chosen, would you get any speed reading, or none at all?
My speed is not working at all and I would like to get the correct pulse setting then start to check my wiring.
I might be wrong (someone chime in here) but I think that, since I hooked up the speed wire to number 53, but my speed limit remover comes before that connection site, that it may be contributing to my problem.
Does anyone know if this would freak out the signal. Should I move down the harness to before the speed limit remover?
Thanks guys, I appreciate all of your help.
David.
David.
