1 - 6 of 6 Posts
Hello,
I would fit a temp sensor on the diff and trans. My idea it's to fit it on the fill nut. I need to find the adapter for the 1/8 sensor but I haven't idea of the size of the oem nut.
Before that I remove it, I would ask if someone can tell me the size for I order the adapter and make the job directly :)
I'd suggest that you'd be better off using the drain plug, rather than the fill plug. The reasoning is that the drain plug will have a constant contact with the oil whereas the fill plug would only receive oil splashes.
TT
I have the greddy diff cover with the inlet and outlet port and I purchased a oil cooler kit on aliexpress ***x1f605;. Actually I still not fit all the parts because my car are still with the engine outside. You need the adapter on the diff cover, if you would take the oem one You can bring it to weld the bung on it and fit directly the inlet and outlet line.
1 - 6 of 6 Posts
