Does anybody know if there is a difference between the bottom Ends of the RB25DE & the RB25DET engines? Do they use the same pistons, crank etc. Can you use a RB25DE with a RB25DET head and turbo system? Does the compression ratio differ between the engines and if so is it due to the head pistons or stroke?
All help will be apreciated.
Also what is the compression ratio of the DET and what is the compression ratio of the DE motor?
Tinus
