Thank you for all the replies. I remember reading somewhere on these forums that the R32's, unlike the 33 and 34, are not always in AWD mode and run in purely RWD until ATTESA decides to transfer power to the front. If that is the case, then it would be okay to run in RWD all the time right? As for the 1% difference in size, would that be enough to make ATTESA crap itself? Also, does ATTESA actually care about the grip between the front and rear? I was thinking that ATTESA only cares that the rear is slipping, so it transfers power until 50% or the rears stop spinning. If that is the case, then I would think that you could run very different sizes without issue. Any ideas on that?
Thank you!
