The other week I was following an r33. Asides from thinking how good it looked when the brake lights come on I did think the eye level led strip in the spoiler was a little dim. Mines the same. Yesterday I had a couple if spare hours so I took my spoiler off and investigated. I found a voltage drop on the wiring to this light. I eased the red plastic off to reveal the led board. There are resistors running along the board supplying 3-4 LEDs each. What I've done is solder a wire across the back of each of these to bypass them. They are not needed because of the small volt drop I have to the back of the unit. Much better! (And cheap and easy)
