I just saw a video clip of a street-legal McLaren F1 LM. More racecar than street, that's for sure. But there was a little detail I caught - the fuel pumps are manually operated. Flip a toggle, and they're on and stay on.
There are a few things I worry about in terms of my fuel pumps. One, that the wiring is too thin (the shop refused to listen to my requests for stereo amplifier wire and ended up using basic stuff), I'm a bit worried about the wiring switch from the car's loom to my fuel pump relays seeing as the wiring loom is quite old and somewhat stiff, and although my fuel system is failsafed against one out of two pumps failing (via two checkvalves), I can't know which one actually failed without taking them out, if a pump does go bad.
But if I have a toggle for each pump, I can not only directly control fuel flow, I can test to hear which pump has died, if indeed one has bought the farm. Since one of my Bosch 044s is enough to provide nearly all my fueling needs (around 90~95%), I could in theory end up running on one pump without realizing it.
Anyone here set up their fuel pumps this way? No relays - just a direct wiring setup, with a 20amp-capable toggle on/off switch, individual switches for each pump?
