Hi all,
Havn't had time to be on here much lately, firstly thanks to all for your kind comments regarding 666, it's still running fine, apart from the fact that the night before its run, it shreded another clutch plate. Good old HKS triples, that's the second time it's done it but this time it took out the bellhousing so the box is out awaiting new b\h. Still, I have a spare clutch plate and gear box, so was only off the road for a few hours
Anyway, the reson for this post is ask you all what colour your tail pipe is? I want to use this info for a project I am working on,
I am also going to bragg like hell now.
Using only OPTIMAX petrol, I got home tonight after doing some tuning (can't afford a dyno yet) where I had the car running flat out in every gear everywere clinching 10500 rpm 1.8 bar boost without any popping or banging... SWEET :smokin:
Shone a torch into my exhaust system and to my absolute joy, it was the most beautiful GREY all down as far as I could see,
so I am well chuffed.
Also, for everybody's infomation, I tried an experiment with CERRACOTE in the standard gear box. It was treated and mixed with MOTUL gear 300 synth and run for 1000 mls. It was drained out completley and I ran my car testing every night 1 tank of juice for 8 DAYS, and low and behold it still lives! I have now put MOTUL only back in and will drive as I always do and see how long the gearbox lasts, bearing in mind 666 has destroyed 2 gearboxes very fast, it will be very interesting to see if it makes a difference. By rights, it should have destroyed the gear box in minutes, I will keep you posted
Gary
GT-ART
THE FUTURETIVE
putting the GT back in the R
Gary
GT-ART
THE FUTURETIVE
