I had high hopes for the power output of my engine going by the specs of it and thought I would get it on the dyno to see if I can try and squeeze out a bit more economy for cruising and also possibly get a bit more power.....but the car produced nowhere near what I was expecting after reading what 2860-5 turbos are capable of making....
The engine was not built under my ownership..it was done in 2008. I do have the paperwork showing the parts purchased and the engine build receipts also.
Dyno graph (flywheel figure): http://i.imgur.com/hIV0A8E.jpg
Current spec of the engine:
Tomei Forged Pistons 87mm
Tomei Con rods
Tomei cams 260c 9.15m lift
Tomei cam pulleys
Tomei valve springs
NISMO N1 oil pump
Nismo Bearings
Nismo timing belt
Nismo fuel pump
Nismo fuel regulator
Garret 2860-5 ball bearing Turbos
HKS Actuators
HKS turbo elbows
Sard 700cc injectors
Splitfire coil packs
Greddy down pipe
Mocul Oil cooler kit
Greddy intercooler hard pipe kit
Oil filter relocation kit
Blitz Nur spec R
De cat
OS Giken twin plate clutch
Apexi PFC D-jetro
Greddy Prospec B
now I am left wondering what I should do to make the most out of these turbos...
I would appreciate any suggestions
The tuner told me two things I need to sort out:
1) I have a 3 inch catback exhaust system. But one of the gaskets on the decat pipe is slightly smaller than 3inches..maybe 2.5..and he mentioned I should definitely sort that out as that will cause unwanted restriction
2) he says both the O2 sensors are not working because when he turned them on in FcEdit software and watched the AFR on idle, nothing changed and the it continued to rise to between 15-16. Apparently, if both O2 sensors work then pfc will run in closed loop and the afr should automatically drop to ideal level..14.7 or something like that.
Below is an image of my PFC O2 sensor readings...its showing voltage movement on idle and driving...but never hits 1.00 volt, actually never went higher than 0.9volts. Sometimes it did drop to 0.00 volts when I was driving but didnt applying any throttle (coasting downhill)...
http://i.imgur.com/Q48tSI6.jpg
Video of Pfc Sensor check screen:
https://www.youtube.com/watch?v=4yIN73hi9OM
Could someone advice me if the O2 sensor is indeed faulty...and also what and if there is anything I could do to squeeze a bit more out of my current engine and turbo setup? Maybe fuelling is an issue?
Thanks very much
Tomei Con rods
Tomei cam pulleys
Tomei valve springs
NISMO N1 oil pump
Nismo Bearings
Nismo timing belt
Nismo fuel pump
HKS Actuators
HKS turbo elbows
Greddy down pipe
Blitz Nur spec R
De cat
Apexi PFC D-jetro
Greddy Prospec B
Thanks very much
