I was wondering how you figure out the actual displacement in cc's after boring and or stroking. Cause alot of the kits out there normally advertise as 2.2/2.7/2.8 etc. For instance, a stock RB26's displacement is 2568cc (2.6L) and the HKS and or Nismo stroker kits i believe bump it up to 2771cc (2.8L).
The stock Bore & Stroke is 86mm x 73.7mm which equals the 2568cc. Supposed i were to bore my engine to 88mm & stroke it 75mm, is there some way of just calculating my displacement by simply using the bore, stroke & number of cylinders or is there more to it?
Thanks in advance.
Thanks in advance.
