Made from the same lightweight aluminium as the Tension Set, this equipment is deigned to reduce body flex from the front and rear of the car. The bars are fixed on the underside of the car following the side skirts and bolt on at each end as well as in the middle of the floor pan on each side. These bars have been used in drag racing and when tested in Japan have been known to reduce ¼ mile times by 3 tenths of a second due to the reduction in chassis flex. These items are also available in mild steel.
Available for BNR34 / BCNR33 / BNR32
Do-Luck Steel Floor Support Bar £240.00
Do-Luck Aluminium Floor Support Bar £300.00
Price Excluding VAT/Delivery
Give the guys in sales a call for ordering / enquiries.
