The Do Luck Safety Brake Signal for the early GTR's without DRL's (Daytime Running Lights - LED front bumper lights) converts the rear lights into 4 simultaneous lights.
The kit comes with an G-sensor which detects G forces and will make the inner 2 lights flash under severe braking in case of an emergency, it will therefor make other drivers behind you aware of a dangerous situation in the hope they can manage to brake just as hard and prevent them from crashing into you.
The kit comes with an adjustable G-sensor which allows the owner to set the G-force detection to his own likings. You can set the system to always flash when you brake or just under hard braking as on a track or emergency stop.
There is no need for any cutting or soldering. It's a straight foward plug-and-play harness which connects to the OEM wiring in the rear of the vehicle. This allows easy installation and removal.
The Safety Brake System for the R35 is available for the Pre and after DRL models.
For cars which come with 4 lights standard (with DRL's) or for cars which already have a 4 light kit from a different supplier or for people who only want the outer lights to always burn and just want the center lights to flash:
Do Luck Safety Brake Signal for R35 - PartBox Performance and Tuning Parts
For cars which come without 4 rear lights standard, the kit comes with a 4 light harness for only a little bit extra!:
Check our demo movies on the link aswell!
These are in stock are ready for shipping from Monday
Click on the below link to go to the video or check out the above links to go our website for other video's
Facebook
Discussion Starter · #2 ·
^ Post can not be edited for some reason.
It's not manually adjustable. We can change the settings if somebody would like it to be adjusted.
First ones will be shipped tomorrow. Thank you for the orders! Still a few available!
