PRICE SHOWN PER WHEEL EXCL TYRE / VAT / DELIVERY
PLEASE ASK SALES FOR A DEAL ON TOYO TYRES
Double six wheels are made to your order, production time can vary.
Worth the wait if you want a real class rim to finish off your Skyline!
Each wheel is constructed of forged alloy and with reverse tyre installation rims which means that tyres are installed or removed from the inner side of the wheel, protecting the outer ‘ show’ edge.
The wheels are available only in 18 inch but with varying offset and width, depending on the required size / application, with the inner spoke section welded in place onto the outer rim.
The wheels can be purchased separately or in sets, each wheel is supplied with a chrome metal inflation valve and each set is supplied with 20 special hexagon wheel nuts, particular to the Double Six wheel. Should you require advice on choosing the correct size wheel for your car, simple contact us for clarification. We can also advise on sizes when using aftermarket body kits to ensure the correct appearance of the wheel against the selected kit.
Do-Luck Double 6 Rim Champagne Gold 8.0J £350.00
Do-Luck Double 6 Rim Champagne Gold 8.5J £365.00
Do-Luck Double 6 Rim Champagne Gold 9.0J £375.00
Do-Luck Double 6 Rim Champagne Gold 9.5J £380.00
Do-Luck Double 6 Rim Champagne Gold 10.0J £385.00
Do-Luck Double 6 Rim Champagne Gold 10.5J £390.00
Do-Luck Double 6 Rim Hyper Black 8.0J £380.00
Do-Luck Double 6 Rim Hyper Black 8.5J £390.00
Do-Luck Double 6 Rim Hyper Black 9.0J £400.00
Do-Luck Double 6 Rim Hyper Black 9.5J £405.00
Do-Luck Double 6 Rim Hyper Black 10.0J £410.00
Do-Luck Double 6 Rim Hyper Black 10.5J £415.00
Do-Luck Double 6 Rim Chrome 8.0J £415.00
Do-Luck Double 6 Rim Chrome 8.5J £430.00
Do-Luck Double 6 Rim Chrome 9.0J £435.00
Do-Luck Double 6 Rim Chrome 9.5J £440.00
Do-Luck Double 6 Rim Chrome 10.0J £450.00
Do-Luck Double 6 Rim Chrome 10.5J £455.00
