What is involved in draining the complete coolant and bleeding the system, where are the draining and bleeding points please.:lamer:
Do you mean, the Drain Plug?
hi Jason
at the time I was putting in Evans oil and wanted to know where the drain plugs for the block,Charles gave me some info I ended up just draining at the radiator and doing 2 flushes with the flushing oil because you cant have water in the system before putting in the Evans oil. thanks for your reply
