Yesterday whilst sat at the traffic lights yesterday the dash flagged up an ABS and EPS warning with the associated warning lights. I have reset the code but it returns soon as I restart the car along with the warning lights and have tried this a couple of times. I have read that tapping the ABS pump might help, where do I find it and what does it look like, also long term I suspect I am looking at recon or replacement, these are not too far away from me Controlunits – ABS pump & ecu repair and look like they can repair and replace for around £300+ VAT
Hi, is it 2009 or 2010? If yes, its a common fault. Change that pump and its fixed.
2009, just tried to tap it and cleared the code, seems to have gone away for now but suspect it weill be back.
My 2010 done same a while back, lit up the dashboard with the various warning lights, Litchfields cleaned one of the ABS sensors (corrosion) and that cleared the problem for over 2 years - lights came back on 2 weeks ago so I'm hoping it's a sensor again.
