Wanted the black plastic trim panel which houses the window switches. Thanks
M mickk · Registered Joined Feb 12, 2006 · 72 Posts Discussion Starter • #1 • Nov 5, 2009 Wanted the black plastic trim panel which houses the window switches. Thanks
RHDJapan · Registered Joined Jan 12, 2006 · 619 Posts #2 • Nov 6, 2009 Is this what you are needing? Nissan OEM Power Window Switch Right Side Front Finisher 22U10 R33 2dr PM Sent!
