I've been changing the oil in the transmission oils and noticed the outer CV boots are split.
Well I tried to put a stretch boot on and in my frustration with it (boot got stuck) I pulled the driveshaft out of the inner CV joint. So the inner boot has come away from the inner joint.
Well I'm a little stuck and annoyed with myself, I also split the stretch boot when it went over the joint.
Can someone recommend a guide or give me some tips on replacing the boots? I still have to do the passenger side next and put the drivers side shaft back into the inner joint and re-do the metal band that fixes the inner boot to the joint whilst keeping it in the front diff (I don't want to take it out)
I got the stetch boot by matching dimensions with the original.
help!
help!
