Do you guys run Dual Wideband Sensors for RB26 ? Is it better than one wideband after the merge at the downpipe?
If you guys do run Dual Wideband Sensors where would you install them? At the OEM 02 location seems too close to the turbo and too hot for the sensors right? And anywhere before the exhaust merges doesn't seem to have the suggested distance away from the turbo outlet.
The best location for the sensor is approx 1 meter from the closest exhaust valve (measured along the central axis of the exhaust pipe) or 1 meter from the turbo outlet ( for turbo charged vehicles)
