1 - 12 of 12 Posts
Go Fast Bits / GFB T9202 Respons TMS BOV
Yep same ones here....sound great!
Whats the difference between the GFB9202 and GFB1101? - is the GFB9202 adjustable (dump or re-circ) or is it only the GFB1101? If it is the difference, do you know if one performs better than the other?
Doesn't Forge produce a BOV? - how does GFB perform against the Forge items?
I fancy some different Bov's and was wondering which ones sounded best. Don't think I've heard the GFB. Best I search U Tube ; )
Discussion Starter #7
Ive been told by Lichfields that they fit Forge ones but what the gent said is that they are not that loud because the R35 has a well sealed bonnet so I'm not sure if I should bother, can anyone tell me different
i have had both, the GFB's are much louder than the Forge ones.. very easy to install (seriously easy) so dont bother getting someone else to fit it.. You can hear them very clearly (even if you have a loud exhaust and the radio on!) especially if you have intakes done
sound wise they are similar its just the GFB is louder, and the GFB is really easy to adjust as well for sound/recirc
Andrew have you fitted GFB9202's or GFB1101's?
1 - 12 of 12 Posts
