1 - 11 of 11 Posts
Hi can anyone tell me if the stock dunlops are directional? I have a 2009 model and want to swap the fronts over so I can refurb 2 wheels from the same side in case theres a slight difference in the refurbed shade.
Dave
Discussion Starter #7
Been reading about TPMS.. If I switch FL with FR will that balls up the TPMS? Will the computer display the pressures incorrectly?
It'll be fine, it works on the frequency and readings transmitted from the valve sensor.
Discussion Starter #9
But would the tyre pressures display vice-versa? so say the original front left wheel (now on the front right) is low - would the computer say front left is low instead of front right ?
Cheers,
Dave
1 - 11 of 11 Posts
