1 - 14 of 14 Posts
dyno results
HAD MY NEW CAR ON THE DYNO YESTERDAY
I WANTED ROD TO MAKE MY CAR VERY DRIVABLE AND TO TIME THE CAMS SO IT WOULD PULL FROM VERY LOW REVS.
I WAS DOWN AT RODS GETTING THE CAR FINISHED LAST WEEKEND HE FITTED THE CAMS,INJECTORS,THEN MAPPED THE APEXI POWER FC.
WE HAD THE CAR FLYING IN 2ND GEAR IT WAS STEPPING OUT SIDEWAYS EVEN WITH THE 275X30X19s IN A STRAIGHT LINE.
ON THE DYNO IT WAS RUNNING AT 1.45 BAR BOOST
IT DID NOT MAKE AS MUCH BHP AS I THOUGHT BUT TO GET GOOD TORQUE YOU NEED TO SACRIFICE SOME BHP.
HE SAYS THAT BY PLAYING WITH THE CAM TIMING IT WOULD MAKE AROUND 520 - 540 BHP BUT I WOULD LOOSE THE LOW DOWN TORQUE.
I THINK I WILL LEAVE IT AS IT IS BECAUSE WHEN DO YOU REALLY DRIVE THE CAR AT 7000 REVS TO GET THE MOST OUT OF YOUR CAR.
POINT TO POINT THIS CAR IS FAST.
SO I THINK I WILL KEEP IT AS IT IS.
AT 1.45 BAR BOOST IT MADE
483 BHP ENGINE POWER.
347 BHP WHEEL POWER.
434 LBF-FT TORQUE AT AN OUTSTANDING 4800 REVS
THIS CAR IS AWESOME THANKS ROD
KEITH
Dyno
Keith
I am just building a parts list for my R33 and am
also looking at low down torque for drivability - Can you
please post your spec ( cam type, turbos etc ).
Also Rod has commented on the benefits of the Apexi FC - What are your thoughts Keith ?
Peter
Discussion Starter · #8 · (Edited)
my car
yes i am very happy with the way it is set up.
the car has very little lag even with the 2530s fitted
pulls like mad and you dont need to rev the nuts off it to get to max power.
they talk about evos having awesome torque at low revs this is almost 100 lbs more at the same rev range.
so you can guess what it must be like.
i have pulled out a old thread on the spec of my car
its under my new car.
i better give rod a plug his email is [email protected]
or you can call him on 07803 616948
keith
Hi Keith,
Glad to hear you're so pleased with your car.
:smokin:
Bet those tyres dont last long.
I should get my car back from Rod at the begining
of next week.
I REALLY can't wait now.
Cheers Tom:D :D
Discussion Starter · #10 ·
YOUR CAR
YES I KNOW I WAS TALKING TO ROD TODAY HE SAID THAT
HE WAS WORKING ON YOUR CAR AT THE MOMENT
YOU CANT GO WRONG WITH ROD BELL
NISSAN EVEN NAMED THE ENGINE AFTER HIM RB 26 HA,HA.
KEITH
1 - 14 of 14 Posts
