1 - 7 of 7 Posts
Heya,
Just in the process of taking some sound away from the car as its ear blowing loud.
I found a good deal on a EBA exhsust, it has the wiring harness and valves, which of course don't do anywhere on my DBA.
I would like to remove the wiring and lock the valve to open.
Anyone know if this could be done easily? or anyone tried this?
Or is it better to do the stock DBA exhaust?
Thanks All.
D.
Because I found a ridiculous deal and haven***8217;t seen any DBA exhausts for sale anywhere.
I believe they fit (don't take my word though ,do more research first?) ,just the valve that does not operate ,the valve is a small removable section anyway so any exhaust fabricators can knock you up a straight piece to replace it with .
Thanks pal, yup the routing is the same, it***8217;s how I get around the value! I***8217;m hoping it***8217;s an easy task otherwise might not be worth it
Nothing on these cars is easy mate. I think it physically fits a DBA, but a CBA would require the valve to be modified or removed, to make it fit. Then you need a really cool missile launch switch in the dash! :)
1 - 7 of 7 Posts
