1 - 6 of 6 Posts
Just connect the proecu cable for the 1st time to read temp history but when I 1st clicked TCM TOOLS it said >2013
Does this mean the gearbox has 2013 software or does it say that no matter what as would be surprised if it did have later software
you need to query the ECU to see what software is loaded into the TCM
I can email you some screen shots if needed.
thanks
thanks
Thanks that would be great
One more thing before I do a clutch relearn I set everything to 0000 do I hit the tab (reset clutch adjustment) or use the plus1 minus1 tabs to zero everything.
Yes I got it thank you.
I didn't reply as in GOSH with daughter and no reception but will be in touch.
1 - 6 of 6 Posts
