Has any gtr owners had such a problem.
To explain, std r34 gtr comes with a egt sensor mounted in the turbo elbow after the turbo.
But if you was to mount the egt sensor before the turbo as is what is recommened for much more accurate readings, and the sensor was to break, would it not destroy your turbo?
What are the r34 gtr egt sensors track record, are they a good quality make, considering they are OEM. Would it be advisable to ditch the old egt sensor for a brand new OEM sensor, would this help void the sensor failure?
Or is there a better quality sensor on the market that is less prone to self destruction and taking your engine with it.
I heard the the sensor needed to be made of a aerospace material 'Inconal'
and so was least likly to fail.
Any info on this subject would be gratefully appreciated.
cheers.
cheers.
