1 - 9 of 9 Posts
Hi on the R33 GTR there is a Electric Aerial Switch what is it for.
Mine when the stereo is switched on the aerial goes all the way up
but if i press this switch it goes down but only half way what good is that and is this correct or broken.
thanks.
Yep; it allows you to run the aerial totally up, or half up. Must reduce wind resistance, or something :chuckle:
Be much more useful if it made the aerial go down completely...
Thats exactly what it is for, its so when you are maxing out at top speed you don't bend the aerial and snap it off, and gives less drag apparently.
mine's also slighty bent,lol
i'll be wiring it up so it goes down,and stays all the way down i hate it when it's out!
1 - 9 of 9 Posts
