Hi guys
my r32 GTR drivers window is stuck down
I can hear the relay clicking in the door when i press the button yet it just isnt going up
i have replaced the switches and the relay box already this year,
anyone else had this problem??
the window is still down at the moment, cant get it up, hope it doesnt rain!
Hi Mate,
This is a very common problem for old Nissans.(including mine!)
It is normally in the relay box (In the drivers door, at the back of the door) Even though it is clicking, it will be either a dry joint or a stick relay causing the problem.
You will need to pull it apart and go over the circuit board with a soldering iron to clean up the solder joints, concerntrate on the relay joints.
ah bugger, that'll be the second relay box gone bang then lol
ive already replaced it once, will buy another and try and repair this as a spare!!
thanks matey much appreciated
