1 - 10 of 10 Posts
changed the battery the other day (cause the old one blew up when i tried to start it up with cables):D
so, i start the car, no problem, BUT;
i have no interior lights, no electrical windows, no gauge light, no 4 wd.
the only electrical that works is the head-lights:(
have already checked the fuses, main fuses, all that i can remember,
anyone to help me,
otherwise i´ll have to buy a new ECU and see if something inside it blew up.
HELP:confused:
cheers
A damaged ecu wouldn't necessarily cause alot of those items to fail. The interior light will just be fed by a fuse. You just need to check every fuse and if it's not that trace it with a multimeter. Check you're getting a live and an earth to the various circuits. If you haven't got a clue about electrics get someone who know what they are doing to have a look. Chances are it's nothing too major IMO.
Give you another clue ... there are two fuseable links (its a bit of wire with a plastic connector each side approx 3inches) that run from the battery positive terminal to the main loom.
They are right next to the positive post, you cant miss them.
Unplug them and see if one has broken ... we are getting a lot of R32s in just now with this fault, hopefully thats whats up with yours :)
1 - 10 of 10 Posts
