1 - 8 of 8 Posts
[URL=http://img366.imageshack.us/i/endlessrdragr32gtr1000h.jpg/]
[/URL]
Car runs 1.7 to 2.0bar boost, has put down 800ps+ with wheel spin (RWD power check) Car weight is circa 1200kg, (lightest car we have ever built) T88-38gk can make 1050ps, so this car has that potential. Ran a shakedown time of 9.4 on low boost...(cold day no track bite) so almost certain it will pull an 8sec run right track and weather permitting and 2.0bar boost.
Spec
Engine:
HKS 2771cc HI-DECK race engine (1 shake down run on overhaul)
Tomei oil pump
Normal waterpump
HKS crank damper
HKS pulley kit
Strong race pulley belt set
Endless-r original alternator pulley (smaller diameter so higher speed)
Full Apexi drag SPL head
280/290 camshaft
Endless-r GTR embossed cam pulleys
Full ported and polished head
Head air out system
Combustion chamber increased and squish removed
1000cc injectors
Fuel pressure regulator
Trust fuel delivery pipe
Full Pro ***** aluminum pipe fuel lines
Endless-R surgetank
Drag racing fuel tank in rear
Battery relocated in car
Oil blobby catch tank
90mm infinity single throttle conversion
2 layer aluminum radiator
4 layer trust intercooler
16row Trust oil cooler
Trust T88-38GK turbo kit good for 1050hp
**special one off transistor processing**
Chassi
Spot welded in key places
FRP doors
Carbon/FRP bonnet
Endless-r Front lip spoiler
Acrylic side windows
Acrylic rear window
Interior
Stripped interior
Bolt in roll cage
Single driver`s seat
Takata harness
Fcon V Pro gold
HKS EVC 5 boost controller
Line lock
4wd switch (puts in 4wd/rwd mode)
HKS Camp 2 digital data logger
Drivetrain
Holinger 6 speed sequential transmission
ATS front lsd
ATS read lsd
HKS triple plate clutch
Front R33 GTR Brembo brakes
Apexi drag suspension
HICAS bar, (all HICAS removed)
Work Emotion 17x9.5 wheels
Hoosier drag tires
Movie: drag runs
YouTube - Endless Drag R32 GTR demo car
Movie: dyno
YouTube - Endless R drag R32 GTR dyno
Yen: 4,900,000 shipped (no offers)
Scary, just checked how much this would have cos this time last year and the year before.
2007- £20961.92
2008- £24377.30
2009- £32224.49
the pound is so weak!!!
2007- £20961.92
2008- £24377.30
2009- £32224.49
man that is depressing . . putting a car potentially in my reach to way out of it :(
what a car though!
hope it goes to a good home!
For 20k, id seriously have considered getting a loan. bearing in mind a holinger is worth 10k on its own!
1 - 8 of 8 Posts
