Hi All, well we are making the boost up rom available to all,
I am not sure how this fairs with other tuners out there, but this is our offering. Its a 1.4kg/cm boost up setting We made a tad over 590hp on one R35, then made a tad over 600hp as you can see here.
Torque was very impessive, and the only mod on the cars was different exhausts. Both having a cat back system.
We were using 100octane pump fuel, and got the following results, dyno room showed temps between 23~26ºC on the day.
If once of you would want this added to your R35, as I wrote we will need your ECU from your car and it will need sending to Japan, to which we will turn it around with in 24hrs and have sent back to you.
