Hi all
Im looking at doing an engine and transmission conversion on a different car (not a skyline) from standard inline rwd setup to 4x4 using an RB26DETT engine and transmission.
I realise the amount of work i have to put in, this is no problem as i have done an engine conversion before. But with never working on a skyline i have no idea what other parts i will require for this setup
so i have just a few questions
1. Is the front diff part of the engine sump or is it mounted on a sub frame.
2. Are the diffs electronicaly controlled or would i get away with using my original rear diff off the car which can handle the power.
3 Does anyone know where i could get the complete standard or close to standard engine, transmission and wiring diagrams from, ive had a search over the net for these things and couldnt seam to come across anything
4 Is the transfer box part of the gearbox
at the moment i know that i will need;
complete engine
transmission.
engine ecu
wiring diagrams
front diff
rear diff
front hub and strut assemblys
idealy i would be looking for a write off complete car that i can use as a doner car.
any help would be greatful on this
Eddie
complete engine
transmission.
engine ecu
wiring diagrams
front diff
rear diff
Eddie
