i'm having problems with my nissan skyline r34 gt. the engine management light randamly comes on and off. when this happens, it judders, and runs really slow and has no power, also it is well below 1000 revs when the light is on and i am at traffic lights. almost nearly cutting out. then it'll just suddenly fix it self and the engine management light goes out and suddenly it returns to normal. there seems to be no certain pattern, engine hot , cold etc.
just happens randamly.
any suggestions greatly appreciated, thanks.
Sounds like some kind of loose connection, or sensor malfunction.
Use the search function for instructions on how to do the diagnostic test, this should show up which sensor is causing the issue.
I just had the same problem with my nissan skyline R34 GTT.
It turned out to be a coil so that would bring on the lights and cause you to loose power
