Hi there guys i have a preassembled short block assembly, i need to put turbos on and damper pulley alternator and all ancillaries.... any one know where i can get a work shop manual need torque settings for a few odds and ends
Flywheel bolts
Crank damper bolt
exhaust manifold etc the list is big wont mention it all here.
Hope you can help as i have been searching only found a r32 manual and the engines are some what different in technology i presume also in tightening values through the years after nissan learnt through the many trial and errors .
Newer manual should equal newer revised values.
thanks in advance
Flywheel bolts
Crank damper bolt
thanks in advance
