1 - 6 of 6 Posts
Anyone know why my engine warning light comes on when I push above 7000 revs? The car is a R34 GTR. I only noticed it today for the first time. :confused:
Any help will be appreciated.
Cheers...........Jeff
Are you running a powerFC or a Nissan ECU, as they both control the engine light in a very different way.
I am running a Power FC
Power FC is often connected by the installer/mapper to the engine warning light to indicate that DET is occuring.Check with your tuner if this is the case and get it sorted before worse happens. 7000+ for now is a no no!
How fast does it go on/blink,maybe its knock or injector duty,when you have the controller in the car,try to monitor the knock and injector duty + record the peak numbers. so you can see why it goes on.
Alex
Thanks guys, I have booked it in! Cannot risk anything.
Cheers............Jef
1 - 6 of 6 Posts
