1 - 10 of 10 Posts
Hi guys. I***8217;ve had the above lights come on after recently driving my car after it***8217;s been sorn***8217;d off the road for about 5-6 months over winter. Having done some research, it appears these can come on when the negative battery connection isn***8217;t great, which mine wasn***8217;t. I***8217;ve reconnected and tightened right up but the lights are still on and I need to reset, and hopefully I***8217;ll have those features return and all working well again.
I only have a stage 1 EcuteK currently but don***8217;t have the Bluetooth dongle etc to reset the faults.
Any of you guys in the Sussex/Hampshire border area that would be willing to help please with a quick reset?
Also, I***8217;ll probably end up buying the EcuteK Bluetooth dongle eventually for instances like this and low tyre pressure fault lights (previously had a couple), and was wondering if there are any good deals out there for one of these? All help/advice much appreciated as always guys.
ABS pump is favourite but check wheel speeds on ecutek first.
Ooo Matron !
Make sure you clean the battery posts as well. Give them a rub with some emery paper to get rid of any oxidation and smear a bit of vaseline on them as well. That will give you a good electrical connection.
Also, when I had an Esprit years ago they were well known for ABS faults. One method was just to drive at around 10 mph and then stand as hard as you can on the brake pedal and that would clear all the dirt off. You could give that a try.
Thanks Takamo. Will do. Interestingly when I washed it a few days before after driving it out of the garage, there were no warning lights illuminated at all. Then after it being sat in the garage a few days the brake pads ‘adhered’ to the discs quite a bit from the surface water resulting in the jolt of the car when they released when driven forward. So maybe this has thrown the sensor out or something, or dirt has been dislodged. I assume I will still need to reset the fault codes regardless though?
Discussion Starter #6
I’ve never had this issue before, and to be fair after the fault I still drove the car pretty hard for a few miles with some very firm braking at times from a decent speed :eek: so I’d think any dirt left on the discs/pads is well and truly gone.
Ooo Matron !
Mine does that a lot. It can take a bit of throttle to release the brakes when I reverse out of my garage. That's why I always take it for a couple of miles after I've washed it so it dries the discs off.
Discussion Starter #8
Agreed and normally I always do the same, but I was rushing that day pending going away so ran out of time unfortunately.
Still hoping someone out there nearby with ecutek that can help me reset the fault codes please (?)
If its the pump they will just come back on but when the new pump is fitted they will disappear no need to delete, done loads now.
If it is the sensor or abs ring it'll clear up after a brisk drive, should turn off itself, if not turn off the ignition then restart it and it should clear the fault and light
1 - 10 of 10 Posts
