hey guys just did my first few thousand km's on my new r33. did my oil change myself...all was successful, oil filter changed and good oil level, filled with castrol 10 w 60 m power oil...(good choice?)
anyway the first time i took the car out, my oil pressure guage on the nismo odometer is jumping all over...any ideas? might i have damaged an oil pressure sensor when changing the oil filter or something? i have no oil leak, and my temp seems good so whats the reason?
the pressure guage at initial start of motor immediately climbs to around 7 then chills around 4 (middle) but pending on throttle ranges from anywhere between 2.5 and 7...any ideas guys? thanx for taking a look.
oh shes pretty much stock.
isnt this normal...oil pressure is higher when cold then drops off when it warms...also rises when you press accelerator as engine spins the oil pump :)
