I am looking at exhaust design at the moment and I want to see if some of you guys can help me out.
the Kakimoto Dual exhaust (not full Dual) goes from the decat pipe into 2x 70mm pipe into 2 rear silencer.
While the HKS Ti goes from the decat into 85mm pipe that expend into a 102mm pipe.
I know the 102mm pipe works as Nito has proved on this To4Z R34. However, ground clearance will be an issue along with the cost (4 inch bore pipe are expansive).
My question is will a design like the Kakimoto exhaust (2x 70mm) be as efficence in reducing back pressure as the HKS Ti (1x 102mm)? Or is the only way is to buy it, put it on a dyno, and find out? They both have a bottle neck which is the downpipe and decat pipe, so they all start out at around 75mm.
