1 - 8 of 8 Posts
What temperature does the warning light for exhaust gas temperature come on at on a R32 GTR? Mine comes on at full boost. Mods are
HKS Induction Kits
Aftermarket Downpipes, De cat and system
Greddy E-01 set at 0.95Bar on std Turbos
Power FC
1 Grade colder Plugs
I assume i need more fuel. Also an EGT Gauge.
Your Power FC is trying to tell you that you are detonating (knocking) at full boost. I didn't know either - 4 months in the shop and $7000 for an engine rebuild, and I got sorted out. Wish I'd have known that (that the PFC uses the EGT light as a warning for knock and injector overload), then I wouldn't have killed my car in the first week of ownership...
when that light blinks, get off the gas - fast. and get a remap or you'll have gone through what I did, and it sucked ass.
ah right. I cant see the injectors maxing out with this level of tune. So it's not the exhaust gas temp?
if the pfc has been mapped somthing is wrong if you have fitted it and not mapped it get it mapped ithink any thing over 40 ish knock isnt good an unmapped pfc doesnt put on the light untill about 60 but i reckon thats major danger zone i was running 1.4 bar(steel tubs) and i never got over 30 knock
the light blinks or flickers, yes? If you're on stock injectors you can max your injectors at 1 bar. But I'll bet anything you're knocking - set your commander to monitor only knock, and press on the up button when the monitor is live so you get a peak reading too. Anything over 30 should give you grave concern, past 50 and you should be scared about blowing your pistons, conrods, crankshaft, or all of the above - and the PFC doesn't flicker the EGT light until you hit 60.
Discussion Starter #7
after more research i have found the r32 has no engine check lamp. Bloody cars. I'm just gonna get it re mapped
your PFC can be set to give warnings, or not. In the ETC menu, you can select which, if any, warnings get transmitted to the EGT light. What are your numbers after a hard pull, for knock? injector duty?
1 - 8 of 8 Posts
