1 - 18 of 18 Posts
id say 3.5" would be good for about 600hp, what are your flywheel output?
486 at the wheels must be around 550ish at the fly????
if it is then id say there isnt much room for improvement with this exhaust
but im sure someone with more tech info should give you a better idea
alex
If you are running the stock size cat flanges, they are normally around 3" anyway, and where the restriction will be.
So exhaust diameter after the cat is of little importance.
Even so, 3" is still capable of 700-800 bhp, probably not ideal, but still.
Done more often than you think, the HKS T51R and T04Z kits, both downpipes neck down to less than 3" to join the CAT, as I guess most Jap kits will do.
Not much point having a 4" cat back if you have to go through a 2.8" restriction in the downpipe.
yea i agree, but i think alot of people are unaware of this exact point
they change everything and leave the stock dumppipe on, causing the restriction
but the faster the exhaust gases get out the less the turbo has to push it out
but i do agree on the restriction of the existing stock pipe flanges
alex
In that case, I would wonder whether there would be any difference at all between 3.5" and 4".
The back pressure just after the turbine is what you don't want, and with the 3" cat flanges you already reduce the bore to less than 3".
According to Corky Bell (Maximum Boost), a maximum exhaust gas speed of 250ft/sec or less is desireable, and he lists a chart, where a 3" pipe will be capable of aproximately 720bhp before the 250 speed is exceeded.
For reference a 3.5" bore would support a little over 900bhp, and a 4" close to 1100bhp
thats the turbo i am going to use!!
you say it will run on my 3.5inch exhaust????
i was told to upgrade it to a 4inch job
alex
hi alex,i was told by the ozzies to use a 4" dump pipe down to the gearbox then reduce to 3.5" its coming out of the rear of the turbo where its most important, done 8000 miles in mine now no issues..bernie
Discussion Starter · #18 ·
That is an impressive set up, What i gather is that 3.5 inch is fine for the power but its the dumps right off the turbos that matters.
So a Tomie or Mines would be the ideal choice for a non custom set up.
thanks
1 - 18 of 18 Posts
