1 - 7 of 7 Posts
I know you still browse the board quite often, so I'd like you to answer mps.
Considering your main activity on this board is buying and selling stuff, maybe you should avoid selling parts which doesn't really match the description you've made of them...
IMHO it would be a good starting point.... :rolleyes:
maybe you should post your problem to warn others untill your problem has been sorted out?
Is that allowed mods?
Maybe a dispute forum/thread would benifit this forum?
Discussion Starter #4
I bought him a PFC D-Jetro which was supposed to be mint and which should have come with Commander, both map sensors and harness.
He replied to pms everyday and shipped parts fast enough.
It "only" happens that:
- there is only one map sensor instead of two
- the harness of map sensors seems to have been modified
- original connector which allows to plug the map sensors harness have been removed and other connectors have been soldered to the board of the PFC
So it doesn't quite match the description of the item and one part is missing... That's why I'd like to hear from him...
(BTW, received mps from other members also disappointed by him...)
Discussion Starter #6
Surprisingly, it seems that he doesn't post anymore... but he still comes here to browse the board.
Can't moderators do anything?
PM Moley et Mook et explique ta situation
1 - 7 of 7 Posts
