can any 1 tell me the best way 2 find fualt codes as i need 2 find why my car is running rich ,it hesatateing because its running 2 rich am a little anoyed as i thought it was coils but iv just replaced them with spitfires:mad:
There are two pins you can short out on the diag plug (end ones but can't remember which) that will flash up the check engine light to give fault codes. This will probably not give you the fault unless it is a total component failure. If its rich on cruise then look at the lambda or afm.
