Administrator
  1. Q60 COUPE TRADITIONAL CAT BACK
    PART # FI-Q60-CB-SST
    Available Options:
    Model Year:
    --- choose option ---20142015
    Drivetrain:
    --- choose option ---2WD (Rear Wheel Drive)AWD (All Wheel Drive)
    Transmission:
    --- choose option ---6MT (Manual)7AT (Automatic)
    X Pipe:
    --- choose option ---Non Resonated12 Res.18 Res.
    I acknowledge that I have read, understand and agree to the terms of the Fast Intentions Inc. Purchase Disclaimer.
    Click here for more details
    $1,680.00 $1,430.00
    QTY.
    ADD TO CART
    REVIEWS
Fast Intentions is proud to present our Q60 Traditional Cat Back Exhaust System.
This cat back exhaust system is the premier upgrade for all Q60 coupe owners looking to maximize the performance from their VQ37VHR V6 engine. Our exhaust system will enhance the sound that Infiniti created from the factory by making it deeper, smoother, and louder.
Built as a direct OEM replacement, our exhaust system is easy to install with simple hand tools; no cutting or welding required. All of our exhaust components are T-304 stainless steel with 2.5" tubing that is mandrel bent to maximize exhaust flow and efficiency. The X Pipe is designed to increase low end torque and maximize power throughout the entire RPM band. This exhaust system is unobtrusive at idle and cruising speeds; but comes to life at wide open throttle. The addition of this exhaust system will improve the aesthetics of your vehicle with its sporty and classy appearance. In terms of overall sound, this cat back is our quietest option available.
PRODUCT INFO.
  • Direct OEM replacement; no cutting or welding required
  • 2.5" T-304 mandrel bent stainless steel tubing.
  • 5" x 9" oval, 14" long polished stainless steel perforated core mufflers.
  • 4.0" resonated dual walled slash cut polished stainless steel exhaust tips.
  • 3/8" thick mild steel flanges. All flanges are bright nickel plated to eliminate potential corrosion.
  • All flange connection points are precision Tig welded around the outside. The inside is sanded down and port-n-polished for a smooth exhaust flow. This process reduces exhaust turbulence at the flange connection points.
  • Non resonated, 12" or 18" stainless steel perforated core resonators within the X Pipe. Resonators reduce interior noise without affecting performance.
  • Limited 3 year warranty on all welds, craftsmanship,mufflers andtips.
  • Application Specific: 2014-2015 Infiniti Q60 Coupe.
  • Compatible on Left and Right Hand Drive vehicles.
  • Not compatible on Q60 Convertible.
  • Gaskets, hardware and installation instructions are included.
  • Hand built in the USA.
BENEFITS
  • An increased average of 15 rear wheel horsepower & 10 foot pounds of torque over the factory exhaust.
  • Refining the factory exhaust note by increasing depth and volume.
  • Reduction in EGT's (Exhaust Gas Temperature) by freeing up back pressure.
  • 47 lbs. w/ stainless steel mufflers; 16 lbs. lighters than factory exhaust.
ADDITIONAL INFO
  • This product is hand built (in house) to order with a standard lead time of 6 - 8 weeks. Once your order is placed, you will receive an invoice with your estimated shipping date. Note: The lead time may fluctuate less than 6 or greater than 8 weeks based on order volume.
  • California customers are subject to sales tax.
  • Customers outside the continental U.S. are subject to additional shipping charges.
