I’ve had a long brake pedal for a while. Feels like the brake fluid needed changing as it was getting longer. Even my wife commented on it!
I’ve changed to Motul 660 and bled in correct sequence taking off tyres to bleed both nipples from each of the calipers. Pads seem fine. Is there anything else I can do to give the pedal less travel?
Brake master cylinder brace.
Braided brake lines.
