Hi Guys,
Well I have managed to find a mint R33 GTS-T, in standard form.
I have had a turbo timer installed and everything else seems standard
Now I have thought about putting the de cat pipe in, but I have been told by my mechanic friend that installing the de catpipe, with out a boost controller may cause issues.
So my question is:-
1. Can I remove the cat, and put in the de cat pipe, without worry ( Just unleash a few horses! )
2. If I need a boost controller, which one should I get, as I have seen many different models and specifications
3. Oh and whats the best air filter to go for, as he also stated that getting rid of the air box would only change the engine note and would be a waste of time.
Thanks in advance
Izi
well, the guy is a knob.
1. you can remove it, except not massive point if you still have standard exhaust system. i would do both!
2. loads of models, and there will be some here how have opinion.
3. loads out there. and it makes a massive improvement to the sound of the car! does increase power a bit, but you need the exhaust as well for full benifit. my blitz suz filer is pretty good imo, but there are better ones for filtration.
